Civil 3D Forum
Volume report problem
9 REPLIES 9
Message 1 of 10
novais
4628 Views, 9 Replies
After changing from C3D 2010 to 2013 i'm unable to view the xml volume report generated on my browser like i normaly used to do in C3D 2010.
I know that i'm doing everything right before trying to generate a volume report since i'm able to produce a table showing my corridor sections and volumes ok.
But when i trie to generate a xml, it pops out blank... Any ideas why this is happening?
Thanks!
Novais
9 REPLIES 9
Message 2 of 10
wfberry
in reply to: novais
Try a different browser.
Bill
Message 3 of 10
novais
in reply to: wfberry
I've already tried Internet Explorer and Chrome... still pops a blank page...
Thanks for your reply.
Novais
Message 4 of 10
ghlad
in reply to: novais
Doesn't work with Firefox either: I just get a blank page when I open the file.  The option to display XML also doesn't work.  I have to manually open the file, which gets buried in a user temp folder.
Greg
Greg
Civil 3D 2020
Windows 10 Pro
Intel Core i7 @ 3.20 GHz
64-bit OS 16 GB RAM
"What sane person could live in this world and not be crazy?" Ursula K. Le Guin, brainyquote.com
Message 5 of 10
novais
in reply to: ghlad
In my case i've found the problem.
With my home PC it works ok with any browser, so the problem was on the tight security policy that my company has with internet and browsers blocking scripts and other things.
Hope the info could help you.
Nuno
Message 6 of 10
ghlad
in reply to: novais
Thanks.  I couldn't find the security setting related to script files in Firefox (my default browser), so I installed MS Internet Explorer (it had been disabled) and associated XML files with it instead of Firefox and the Volume Report works now.
Greg
Civil 3D 2020
Windows 10 Pro
64-bit OS 16 GB RAM
Message 7 of 10
reyfabian2015
in reply to: novais
Im having the same problem, I already have the scripts enabled in both google chrome and microsoft edge however it is still blank or with the error "This XML file does not appear to have any style information associated with it. The document tree is shown below"
Message 8 of 10
AlekseiOn
in reply to: reyfabian2015
Same here. Windows 11 Civil 3D 2023. Chrome and Edge scripts allowed, pop up allowed.
Then i make table of pavement materials separably,  i have got the numbers. Then i try to use Material report, it generates only xml file, without html in Temp folder. Earthworks report working fine. Any solution?
Message 9 of 10
Bholle
in reply to: AlekseiOn
Just had the same issue. Had to enable Internet explorer mode on Edge to get it to work.
Message 10 of 10
hugomABZ3T
in reply to: novais
This worked for me as well. In the top right of Microsoft Edge, click the 3 dots for the drop-down menu and down near the bottom, select: "Reload in internet explorer".
It will reload and give a pop-up to allow scripts.
Rail Community
