I am using C3D 2012 and i know how to create a table showing volumes for different elevation ranges with different colours, but does anybody know how to show the total cut or fill for the volume surface in the same table so that you dont have to manually add up all of the cuts or fills? or have to display only two ranges?
Thanks, Patrick
Isn't this a total PITA??
You could specify the ranges as 0-1, 0-2, 0-3 etc rather than 0-1, 1-2, 2-3 - that may do it??
OR
explode the table to lines and text, use a lisp to create a plain CAD table and then use plain CAD functions or export to Excel
