I have a single surface, a pond, that I want to calculate the volume of. Is there a way I can have Civil3D tell me the volume of a single surface, without a comparison surface?
I understand that without a comparison surface C3D does not know where to calculate to, but... when I'm doing a simple pond with a top elevation and a bottom elevation, it would be nice to just get a rough idea of the volume without having to make a top of water surface, or measuring the area of the top and bottom and calculating the volume myself. There's got to be an easy way to do this, right??
Mark Green
Working on Civil 3D in Canada
There is also the method of calculating a volume from a datum elevation - I think it is command line only though; reportsurfboundedvolume but may need a volume surface to work?
Have you looked at the Stage Storage tool? It reports pond storage volumes at specified depth increments. The tool is found on the Design panel of the Analyze Tab (see the pull down on the panel). See also StageStorage in the help system.
Stage Storage is the ticket. It's quick and easy, generates incremental and accumulative volumes from an existing surface or just from polylines at elevation if you want. No need for a second comparison surface. It generates a report instantly as well. You can choose to calculate volumes using Average End Area or Conic Incremental methods, or both.
Mark Green
I've not used it in a real world project. It's good to know there are problems with it. Looks like another half baked tool.
I have two ponds in a surface. The stage storage reports on of them 😞 Is there a way this command reports both?
