Hello Everyone
I have an issue with volume calculation. In a valley, i need to put a dam for a reservoir (i hope i'm using the correct technical terms)
then, i need to know the volume of it and i used the Civil3D tool for it. as expected, it generates a new volume, but the shape of it makes me doubt about its results
as you can observe above, the two shapes are not the same... I expected a dam like shape but it results inverted. I can imagine its because a surface is not a closed volume, so Civil 3D needs to adjust it's shapes so it can be a civil 3d acceptable shape, but with the volume result, i'm not sure about its magnitude.
Does anyone have an issue like this? have someone verifed (with a third opinion or (even better) the experience) if the civil 3d volume calculation volume match with other calculus or reallity?
i'll appreciate your opinions.
thanks in advance
