Not sure why my volumes are showing Out of Date. It happened after a save on the drawing. My surfaces are not out of date, but the corridor were also flagged.
Solved by Jay_B. Go to Solution.
I'm not sure what causes it either but have this same issue in one of my dwg's.
Interesting you have 2 volume surfaces listed and the file I have trouble with does as well. In another file using the exact same Dref'd EG surface with just one Tin Volume Surface it does'nt have the issue.
As far as I can tell it only seems to be a nuisance issue. Once the Out of Date Tin Volume Surfaces are rebuilt, the Volumes are repopulated in Volumes Dashboard.
Save>Close>Open dwg and they are once again out of date.
Civil 3d 2014 SP1.
