Active Member
0 Kudos
Post 1 of 5
Volume comparisons in Civil 3D 2012
2273 Views, 4 Replies
03-06-2012 04:38 AM
I learned everything on AutoCAD Civil 3D 2010. I remember a while back, I created two surfaces to do a volume comparison. Mainly I was interested in a cut/fill analysis. When I compared the surfaces, it created a new volume entity (for lack of knowing what it was technically called). The icon for this new entity was different from the icon for a surface; the new icon looked more like an extruded version of the original surface icon, if that makes sense. From here I was able to color areas that were in cut or fill, plus all sorts of other visual things.
So my problem: I am now using AutoCAD Civil 3D 2012. I have successfully created two surfaces and done a volume comparison. I can get the cut/fill from panorama, but I don't see any new entity created for this comparison. I am interested in coloring my plan for areas of cut and fill, for a quick visual representation. Has this feature been eliminated or changed in 2012, or am I missing something? Is there possibly something extra that I need to install? I am using the student version, but I have always used student versions.
Use a surface analyis as per screenshot
Glad its sorted - my version is UKIE specific and so refers to Levels rather than Elevations
Please could you mark as solution (and give kudos) :smileyhappy:
343 Kudos
Post 2 of 5
Re: Volume comparisons in Civil 3D 2012
03-06-2012 07:41 AM in reply to: mattsears18
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Member
0 Kudos
Post 3 of 5
03-06-2012 09:59 AM in reply to: mattsears18
Thanks, I think we're almost there. Some reason I don't have "Levels" as an option. Any idea?
See attached
Active Member
0 Kudos
Post 4 of 5
03-06-2012 10:10 AM in reply to: mattsears18
Solved. Had to create "TIN Volume Surface." That's what I was forgetting.
343 Kudos
Post 5 of 5
03-06-2012 12:48 PM in reply to: mattsears18
neilyj
