Hi:
I have a volume in my CAD file described by 3D Faces. Is there anyway to know what is the volume of this volume -that represents an open pit-?
Every time that I do a volume I do by the comparison of 2 surfaces but this is not the case now.
Thanks in advance
Rafael
in order to get the volume of a pond for instance if it is filled to elevation 979.00
a flat surface using a rectangle with elevation 979 which is larger than the pond is used to compare to the pond surface.
does this make sense?
Do the 3D faces represent the pit, or the volume of the pit? The way you wrote it makes me think the latter. Where did they come from? It is possible that a Volume surface was exploded or had the 3D faces extracted from it. If that is the case, you need to build a surface from the 3D faces and another surface at elevation zero, and compare the two.
Mark Green
Working on Civil 3D in Canada
Hi Troma, thanks for your long replay:
The 3D faces that I have represent the Pit. So trying to to clean the file in order to get the 3D faces that represent the surface of the pit is almost....impossible.
There is not way tof calculating the volume taking the 3D faces in the way I am describing?
Rafael
What do you mean about 'Cleaning' the file?
If you have 3D faces that represent the pit, you can use them to build a TIN surface that duplicates them exactly.
Then you need to create another surface at the top of the pit. That will either be flat, as described earlier by others, or you could match it to the top of slope of the pit.
You can then calculate a volume between the two surfaces.
Mark Green
Hi:
Thanks for the solution. I was lucky that the file came not only with the Volume that descrbed the pit but also with the Surface that described the same pit in a different layer, then I build the surface so I can now calculate the volume comparing this surface with the Original Ground surface
Regards
Rafael
