AutoCAD Civil 3D General Discussion
Active Contributor
0 Kudos
Post 1 of 5
Visibility issues
61 Views, 4 Replies
05-17-2005 10:40 AM
I generated my profile and I turned some of my labels' visibility to "FALSE" so they wouldn't clutter my profile. Since they aren't visible anymore, how do I turn that specific label's visibility to "TRUE"?
Active Contributor
0 Kudos
Post 2 of 5
Re: Visibility issues
05-17-2005 11:16 AM in reply to: mherranz
Along the same trend; Is there a minimum length variable to set so the labels will be visible? I've got, in my profile, a V-Pan and adjacent to that a VPI. I'm not getting any of the deflections on my profile labelled.
Any ideas why?
Active Contributor
0 Kudos
Post 3 of 5
05-17-2005 11:39 AM in reply to: mherranz
Ok, I figured out my second issue. It was under the weeding distance column.
*Daniel Philbrick
Post 4 of 5
05-17-2005 12:49 PM in reply to: mherranz
If you select the profile-> right click -> edit labels you will get a list
of the label styles which have been applied to the profile. If you have
overridden the visibility (or other properties), the "Reset" button in the
upper right of that dialog will be enabled. Selecting that button will
clear the overrides for that type of label.
Dan
wrote in message news:4847692@discussion.autodesk.com...
Active Contributor
0 Kudos
Post 5 of 5
05-18-2005 04:14 PM in reply to: mherranz
Thanks, Dan, it worked.
Marco
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
