Civil 3D Forum
Visibility issues
4 REPLIES 4
mherranz
108 Views, 4 Replies
Visibility issues
I generated my profile and I turned some of my labels' visibility to "FALSE" so they wouldn't clutter my profile. Since they aren't visible anymore, how do I turn that specific label's visibility to "TRUE"?
4 REPLIES 4
mherranz
in reply to: mherranz
Along the same trend; Is there a minimum length variable to set so the labels will be visible? I've got, in my profile, a V-Pan and adjacent to that a VPI. I'm not getting any of the deflections on my profile labelled.
Any ideas why?
mherranz
Ok, I figured out my second issue. It was under the weeding distance column.
If you select the profile-> right click -> edit labels you will get a list
of the label styles which have been applied to the profile. If you have
overridden the visibility (or other properties), the "Reset" button in the
upper right of that dialog will be enabled. Selecting that button will
clear the overrides for that type of label.
Dan
wrote in message news:4847692@discussion.autodesk.com...
mherranz
Thanks, Dan, it worked.
Marco
Rail Community
