Member
chris.pettigrew
Message 1 of 15 (1,919 Views)
VIEWPORT TYPE
1919 Views, 14 Replies
04-16-2012 02:35 PM
Typically when setting up a viewport in paper space I can change the viewport type at the bottom of the properties dialog box. In 2013 the option is available, but it will always snap back to undefined. I'm sure it is a setting somewhere. Any help would be appreciated. Thanks,
Sinc
Message 2 of 15 (1,901 Views)
Re: VIEWPORT TYPE
04-16-2012 07:48 PM in reply to: chris.pettigrew
Interesting...  I seem to be noticing the same problem.
Guess I need to explore this and try to figure it out, since I'm supposed to be doing some training later this week in how to create P&P sheets...  I hope nothing is broken in C3D 2013.  (Luckily, I think we'll be using C3D 2012, and not C3D 2013...)
Sinc
mathewk
Message 3 of 15 (1,865 Views)
Re: VIEWPORT TYPE
04-17-2012 10:38 AM in reply to: Sinc
I am having the same problem.  No soliution yet.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Sinc
Message 4 of 15 (1,849 Views)
Re: VIEWPORT TYPE
04-17-2012 03:38 PM in reply to: mathewk
Kind of a bad problem...
I wouldn't be in a hurry to jump to C3D 2013 just yet.
Sinc
mathewk
Message 5 of 15 (1,845 Views)
Re: VIEWPORT TYPE
04-17-2012 03:51 PM in reply to: Sinc
Interestingly, if you open a 2012 file with that viewport already set, it stays set.  However, you can't change it in 2013.
Matt Kolberg
BrianHailey
Message 6 of 15 (1,833 Views)
Re: VIEWPORT TYPE
04-17-2012 09:41 PM in reply to: chris.pettigrew
I've been able to duplicate the issue on my system as well.
Brian Hailey
CAD-1.com
My Blog
mathewk
Message 7 of 15 (1,830 Views)
Re: VIEWPORT TYPE
04-17-2012 10:05 PM in reply to: chris.pettigrew
I submitted a case to support but I havbe yet to hear back. A fairly serious problem if you're setting up a layout for use with the section and plan production tools.
Matt Kolberg
Valued Mentor
engrtech
Message 8 of 15 (1,818 Views)
Re: VIEWPORT TYPE
04-18-2012 08:50 AM in reply to: chris.pettigrew
I just tried this also and get the same problem.
I think this has been the worst release since r13.
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
Sinc
Message 9 of 15 (1,788 Views)
Re: VIEWPORT TYPE
04-19-2012 12:17 AM in reply to: engrtech
Remember the initial release of 2007...?  :smileywink:
Sinc
mathewk
Message 10 of 15 (1,769 Views)
Re: VIEWPORT TYPE
04-19-2012 07:27 AM in reply to: chris.pettigrew
Found a workaround for this. There is a new property preview sysvar PROPERTYPREVIEW. Turn it off.
Matt Kolberg
