I double click in the viewport; under misc the annotated scale is in the list but not the standard scale. I want to set the scale for the viewport. Why doesn't the standard scale show as on option? Or, how to I set the scale in my viewport?
I'm using autocad LT 2008
Solved by jeff.jsjones. Go to Solution.
Joe Bouza
I must be missing the concept. My other drawing scale changes correct under the standard scale setting. My current drawing has pasted figures. Maybe something is going on that will only allow these to be shown an annotated. Still stuck with a drawing I can't scale.
I solved the problem by using the annotated setting on the right side of the tool bar.
