unbelievable, fist time making multiple tabs in civil 3d for different sheets, like sheet 1 of 3, 2 of 3, 3 of 3 etc... when I right click on the original tab and say copy to make the other 2 sheets and then go into those sheets, when i try to enter model space I can't pan around or anything, what am I doing wrong!??? googling was not much help
Solved by AllenJessup. Go to Solution.
I know you said you tried unlock but since you get 3 objects. Select all 3 objects and go to Properties. Filter for just the viewport and see if it's locked.
Allen
Allen Jessup
CAD Manager - Designer
Select all 3. Open Properties. At the top it will say 3 items selected. Drop that down and select only the viewport.
Allen
Allen Jessup
OK. You have 2 viewports on top of each other. When you double click the one in back activates and you pan in that so you don't see it in the front one. Erase the one that isn't correct.
Allen
Allen Jessup
thanks but HOW do I know which one is the bad one and how do I select that one to delete it?
Select the one on top and move it. Compare it to the one below. If the one you moved is the bad one. Erase it. If it's not undo until it's back in place. select both viewports and remove the one on top.
Allen
Allen Jessup
Glad it worked for you. Just used some old tricks I've picked up along the way.
Allen
Allen Jessup
