Civil 3D Forum
Viewport Locking Up
13 REPLIES 13
Message 1 of 14
580 Views, 13 Replies
Viewport Locking Up
unbelievable, fist time making multiple tabs in civil 3d for different sheets, like sheet 1 of 3, 2 of 3, 3 of 3 etc... when I right click on the original tab and say copy to make the other 2 sheets and then go into those sheets, when i try to enter model space I can't pan around or anything, what am I doing wrong!???  googling was not much help
13 REPLIES 13
Message 2 of 14
I should add that I've already tried the viewport lock/unlock thing, does not help, also if I select the frame of the model space viewport it says there are 3 objects, maybe that gives a clue?? I erase on at a time and still no help
Message 3 of 14
AllenJessup
I know you said you tried unlock but since you get 3 objects. Select all 3 objects and go to Properties. Filter for just the viewport and see if it's locked.
Allen
Allen Jessup
CAD Manager - Designer
Message 4 of 14
in reply to: AllenJessup
how do I filter for just viewport? do you mind writing some simple instructions and I will check?!
Message 5 of 14
are we allowed to upload civil 3d files here? maybe I could do that and someone could help that way?
Message 6 of 14
here is the file if i uploaded it correctly
Message 7 of 14
AllenJessup
Select all 3. Open Properties. At the top it will say 3 items selected. Drop that down and select only the viewport.
Allen
Allen Jessup
Message 8 of 14
THANKS! ... it says there are 2 viewports selected
Message 9 of 14
AllenJessup
OK. You have 2 viewports on top of each other. When you double click the one in back activates and you pan in that so you don't see it in the front one. Erase the one that isn't correct.
Allen
Allen Jessup
Message 10 of 14
thanks but HOW do I know which one is the bad one and how do I select that one to delete it?
Message 11 of 14
AllenJessup
Select the one on top and move it. Compare it to the one below. If the one you moved is the bad one. Erase it. If it's not undo until it's back in place. select both viewports and remove the one on top.
Allen
Allen Jessup
Message 12 of 14
YES!!!!! THANK YOU!!! ... waves of relief ....
Message 13 of 14
AllenJessup
Glad it worked for you. Just used some old tricks I've picked up along the way.
Allen
Allen Jessup
Message 14 of 14
I hear you, pain is the best teacher lol
Rail Community
