Hi everyone. I have a drawing that contains several layout tabs. When I export the layout tabs to a PDF they all appear to export correctly - they save to a file and you can open the PDF and view it. They also all plot successfully to a printer/plotter except one. I have been dealing with this issue for a while and have looked at many posts to try and find a solution. The layout tab that will not plot only contains text (all Mtext and all on the same layer). When I try to plot this particular PDF you get an error message. I have attached the troubled PDF. Any thoughts would be greatly appreciated!
This is maybe the first PDF I have ever seen that is not printing.
Do you have only one way to create .pdfs in AutoCAD? ( I have like three - DWG to PDF.pc3, CutePDF writer , Adobe PDF ). If you have more than one - try with some of the others.
Other option is to open the .pdf file with Photoshop and resave it there again in .pdf. The error disappears.
