Civil 3D Forum
View Surface
10 REPLIES 10
Message 1 of 11
299 Views, 10 Replies
View Surface
I'm new to Civil 3d. I created a surface and it automatically showed an outline of my surface. I would select the outline and right click to turn off and on contours, slope arrows, and etc. Well I have turned off all the layers and I don't know how to show or edit my surface since I don't have any portion of the surface to right click on.
10 REPLIES 10
Message 2 of 11
In the Prospector. Expand the surfaces tree and right click on the name of
the surface - check out the Properties...
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
wrote in message news:5164059@discussion.autodesk.com...
Message 3 of 11
I did that and it shows four tabs. Information, Definition, Analysis, and Statistics.
this is what i was doing before but now there is nothing to selece since i turned all the layers off.
Select your surface, right click, choose edit surface style.
Message 4 of 11
In the Information tab, what is your default surface style?
Change it or go to Settings > Surface Styles and edit the style display from there. Done.
Message 5 of 11
Information Tab shows the style being used - edit the style (see Surface.png
attached). This will open another dialog - change visibility settings on
the Display tab (see Display.png attached).
Before digging any deeper, I'd highly recommend running through the
tutorials found in the Help menu.
sm
Scott McEachron
wrote in message news:5164259@discussion.autodesk.com...
Statistics.
Message 6 of 11
Cool, i found the properties box i was looking for and in the preview it looks and works great. So how do I get the line work (surface) into my DWG.
Message 7 of 11
It's already there, turn on the contours. If you want the triangles, turn
them on instead. If you need to edit the surface, open the surface in the
Prospector until you see "Edits."
Civil 3D doesn't remotely look, act, or feel like Land Desktop; again, I'd
highly recommend the tutorials, they won't take you but a couple hours, and
will save you tons of typing 😉
sm
Scott McEachron
wrote in message news:5164311@discussion.autodesk.com...
Message 8 of 11
Message 9 of 11
First rule of Civil 3D
"It is not Land Desktop"
Second Rule of Civil 3D
But is it worth it, Scott! I promise you!!
Dana Breig Probert
http://civil3drocks.blogspot.com/
http://groups.yahoo.com/group/cadapult_civil
"Scott McEachron" wrote in message
news:5164314@discussion.autodesk.com...
sm
Scott McEachron
Message 10 of 11
Is the third rule "You do not talk about Land Desktop?"
I got to sleep last night. I'm feeling punchy.
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2006 SP2
XP Tablet, SP2, 2GHz, 1.5G
www.eng-eff.com
www.civil3d.com
Message 11 of 11
that's my third and fourth rules
Jason Hickey
http://beneaththelines.blogspot.com
Rail Community
