I created a view sheet set from a view frame (P&P), but the profile text is wayyy too small and I cannot see the major vertical gridlines. How can I change this?
Solved by gjrcmb. Go to Solution.
The display of gridlines is controlled through the Profile View Style | Display tab settings for the style that you are applying to the profile view. Select your profile view and go into Profile View Properties. On the Information tab under Object Style, select the icon to the right to Edit Current Style. On the Display tab make sure the visability for the Grid Vertical Major is enabled. Also make sure that the corresponding layer is on and thawed in the layer manager including the viewport settings.
As far as the text settings, I assume that you are talking about the grid text? This is set in different places depending on how you have your profile view configured. If you are not applying any Bands, then the text size is controlled through the Profile View Style as described above, then through the Horizontal and Vertical Axes tabs.
If this does not seem to affect the text, the profile view is probably applying a Band. Go back into Profile View Properties and the Bands tab. If there is a Band in the List of Bands, select the Band and then click the icon next to the item listed under Style to open the Pick Band Style dialog box. Select the Edit Current Style icon to open the Profile Data Band Style dialog box and the Band Details tab. Select the Compose Label button. In the Label Style Composer and the Layout tab, you can specify Text Heights for the different text components.
As far as other labels on the profile itself, the text sizes are controlled through other label styles.
As a side note, I noticed that when using the Plan Production Create View Frames feature (which I believe is what you are doing) that I am unable to change the selected Profile View Style after the frames are created. In other words if you select a frame and then go into Group Properties, the drop down arrow on the Profile Views tab next to Profile view style to be used it is greyed out. You can still make changes to the underlying style, but you cannot change to a completely different style. I wonder whether anyone else has any insight into this observation?
Thanks for the suggestion Gavin, but it didn't seem to work. I'm attaching the sheet as it prints out. I now have a few problems:
I've tried all approaches but still can't seem to solve it. Any other advice?
Sounds like things are getting worse.
The text settings are configured through various settings and styles, depending on what text you are talking about (Stations, Elevations, Profile Labels, etc). Hard to really check out all the settings without looking at the files, and the image is not really much help. Not sure if you are running C3D 2012, which is what I have, so it's possible we could be looking at different things. Is the text showing up in Model space correctly?
Did you see that a Band is applied in the Profile Views Property? If so, there is one addition to what I said above. Where I indicated to select the Compose Label button, I noticed that there are actually two of those buttons in the Profile Data Band Style dialog box. You need to be selecting the one on the right under Labels and Ticks, as well as selecting what feature you want to compose like Major Station. Not sure if that applies in your situation or not?
Not sure what you mean by chainage?
Was the annotation showing up in the Plan view before? The fuzziness of the Matchlines sounds odd, makes me think something else is going on perhaps with the Plan Production tools. I would like to be able to look at the file, but that may not be practical from your end. If it is practical, send me an private message and I can give you my email address.
OK, thanks for sharing the file with me privately. Looks like with the help of a previous posting by forum contributor "troma" that the small text problem is associated with the Page Setup. Go figure. Thanks to troma!
"Not sure what you mean by chainage?"
Gavin, just for reference.
For "chainage" read "station".
Don't know where emmar0001 is from but we use Chainage in Australia. (As it should be of course :D)
"Station" is what we call a Setup Point for survey instrument.
I have had many hours trying to explain all the various "wrong" terminology that Civil 3d uses. lol
Andrew:
Since we are somewhat off the subject, how long is a chain in Australia?
Bill
Ah, Andrew I appreciate the down under education. Let me see, where is my note pad. It is important to be up on varying terminology locally as well as internationally. Isn't there a terminology style setting somewhere to personalize C3D for different locales, lol.
As far as the subject post, changing the Page Setup as described in my previous post seems to have resolved the problem, per my communications with emmar0001. Kind of a quirky thing, but nice to be aware of.
1 Chain = 100 links = 20.117m
Very good!
Apparently the same here in the States 1 Chain = 66.00 FEET (20.117 M)
Bill
