Show only
Search instead for
I have an alignment that runs from east to west. After generating view frames and sheets, the sheet order shows the alignment running from west to east. Basically the views are upside-down. Has anyone run into this problem? How can I fix this?
Your Viewframe is upside-down. Click on the viewframe and grab the green node and rotate it 180 degrees so that is pointing down from the orientation that you want the sheet to be in.
