Hi
I creating plan and sections from my model. I went through my Create View Frames, and created my sheets fine. But one thing I cannot seem to fix, I am starting from Sheet 10, not sheet 1, so I need my match line to start at sheet 10, then up from there. Whats the setting I need to change for this? I have set all counters to start from 10, but the first match line still says sheet 1 😞 i have attached an image of the matchline.
I don't believe there is, you'll have to rename renumber in SSM
Your Name
Your Name
yes marcross, i changed that number to the number i wanted, but that didnt work 😞
just want to make sure, you have the <Next Counter(CP)> property field included in the MatchLine's Name: right?
did u modify the matchline label styles? it is using Match Line Name or Match Line Number?
