When View/Editing corridor sections, is there a way to display viewports on dual monitors versus just splitting one screen? Ideally, I could view sections on one monitor and the plan view on the other.
Solved by odoshi. Go to Solution.
The Section Editor viewport configuration is designed to work from the Model tab in the same fashion as the VPORTS command. So, unless you stretch the entire Civil 3D application across your screens, you can't really do what you're looking for.
