Distinguished Contributor
0 Kudos
Post 1 of 8
view cube will not stay pointed to the north
730 Views, 7 Replies
11-05-2012 12:36 PM
In the previous versions of civil 3d 2012 or earlier, I never had a problem with the view cube not staying pointed to the north.  Since I never touched it in the past, how do I get it to stay pointed to the north?
1,212 Kudos
Post 2 of 8
Re: view cube will not stay pointed to the north
11-05-2012 12:43 PM in reply to: lissaucad
When you don't use the viewcube, and you don't use commands like _ORBIT or _DDVIEW it should stay with north direction upwards.
My question now is: when does it turn away? :smileywink:
- alfred -
Alfred NESWADBA
169 Kudos
Post 3 of 8
11-05-2012 01:13 PM in reply to: lissaucad
If you are referring to the viewcube being "skewed" a bit, you can type in GEOGRAPHICLOCATION.  When prompted select, Remove the Geographic Location and it will reset it.  This is usually due to using a previous release version template file and opening a drawing with it in a new release.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
343 Kudos
Post 4 of 8
11-05-2012 01:17 PM in reply to: lissaucad
EDIT: Todd beat me to the reply....
This seems to be a problem with 2013 if you have migrated templates etc rather than using the OOTB templates for 2013.
GEOGRAPHICLOCATION > EDIT and set the angle to zero will sort it.
I have my NAVVCUBE variable set to OFF so I can't see it and it'll probably only affect things things like sunlight in renderings
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Contributor
7 Kudos
Post 5 of 8
11-07-2012 06:29 AM in reply to: lissaucad
This happens when you set your file to a coordinate system.
If you use the GEOGRAPHICLOCATION command to remove the geographic location as posted by Todd, it will set your file back to a generic coordinate system, which could cause issues if you are importing or connecting to data.
If you use the GEOGRAPHICLOCATION command to set your angle back to Zero as posted by neilyj, it will only hold this setting until the file is closed.  When the file is reopened, the angle will be skewed again.
"The most dangerous phrase in the language is 'We've always done it this way.'" - Rear Admiral Grace Hopper
169 Kudos
Post 6 of 8
11-07-2012 06:32 AM in reply to: DMFACER
If my drawing is set to a coordinate system, say state plane, and I remove the geographic location, my drawing coordinate system is NOT affected.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
7 Kudos
Post 7 of 8
11-07-2012 06:50 AM in reply to: lissaucad
In all of our testing of this issue, we have not been able to hold the coordinate system of the file if we remove the geographic location.  If we could get it to hold, it would be much less of an issue for us.
Wish I knew what we were doing differently!
169 Kudos
Post 8 of 8
11-07-2012 06:56 AM in reply to: DMFACER
I wish I knew what your were doing differently too.  I can see where that would potentially cause major issues.  Neither I, nor my customers have had the coordinate system default back to a generic coordinate system.  However, you are not alone.  I have read about others having the issue reverting to a generic coord system.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
