Does anyone know if there is a way of referencing the profile view vertical exaggeration in an expression? I'm trying to tweak a pipe profile label that is anchored to the top and bottom of the pipe and want the label to adjust accordingly as the vertical exaggeration changes without needing to creating separate label styles for each profile view style with different exaggerations.
Is this possible?
I usually have only one Profile View style in a drawing, if that's the case for you I'd Create a VerticalExageration expression and have it store a value of the profile view exageration. I'd then reference it in all of the pipe label styles where its required. If the profile view exageration changes, then I only have to change the value in one place and all of the labels will update.
Christopher
