AutoCAD Civil 3D General Discussion
0 Kudos
Post 1 of 6
Accepted Solution
Vertical Curve "r" Value
1148 Views, 5 Replies
06-21-2013 10:05 AM
I need to add the "r" value to the vertical curve labels in the profile (|G2-G1| / L).
Is there a way to add this property to the text component editor?  I see a lot of different components listed, but no "r" value.
The expression you build will become part of a label.  Start by expanding the Settings group for the type of label that you intend to use the expression with - profile curves in this case.  Right click on the Expressions option, and start a new one.
Once you have an expression built it will available in the dropdown list that you can insert into a label style, just like the built in parameters.
ShawnMcCorkle1211 wrote:
I thought that I could manipulate it that way, but wasn't sure how to add an expression.
Can someone walk me through how to add the expression to the components?
*Expert Elite*
343 Kudos
Post 2 of 6
Re: Vertical Curve "r" Value
06-21-2013 10:31 AM in reply to: ShawnMcCorkle1211
k value?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Mentor
39 Kudos
Post 3 of 6
06-21-2013 10:54 AM in reply to: neilyj
The 'r' value (rate of change of curve) is inverse to the K value. r=1/K.
You will probably need to make an expression to show this value.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
0 Kudos
Post 4 of 6
06-21-2013 11:09 AM in reply to: ccoles
*Expert Elite*
418 Kudos
Post 5 of 6
06-21-2013 07:17 PM in reply to: ShawnMcCorkle1211
0 Kudos
Post 6 of 6
06-22-2013 05:27 AM in reply to: sboon
Thanks for the help.  That worked perfectly.
For some reason the Expression Option was not present. After repeated closing and restarting C3D, it finally appeared.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
