ShawnMcCorkle1211
Message 1 of 6 (1,043 Views)
Vertical Curve "r" Value
1043 Views, 5 Replies
06-21-2013 10:05 AM
I need to add the "r" value to the vertical curve labels in the profile (|G2-G1| / L).
Is there a way to add this property to the text component editor?  I see a lot of different components listed, but no "r" value.
neilyj
Message 2 of 6 (1,038 Views)
Re: Vertical Curve "r" Value
06-21-2013 10:31 AM in reply to: ShawnMcCorkle1211
k value?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Mentor
ccoles
Message 3 of 6 (1,029 Views)
06-21-2013 10:54 AM in reply to: neilyj
The 'r' value (rate of change of curve) is inverse to the K value. r=1/K.
You will probably need to make an expression to show this value.
Windows 7 64-bit
HP Z600 8 Gig RAM
Civil 3D 2013
ShawnMcCorkle1211
Message 4 of 6 (1,022 Views)
06-21-2013 11:09 AM in reply to: ccoles
I thought that I could manipulate it that way, but wasn't sure how to add an expression.
Can someone walk me through how to add the expression to the components?
sboon
Message 5 of 6 (997 Views)
06-21-2013 07:17 PM in reply to: ShawnMcCorkle1211
The expression you build will become part of a label.  Start by expanding the Settings group for the type of label that you intend to use the expression with - profile curves in this case.  Right click on the Expressions option, and start a new one.
Once you have an expression built it will available in the dropdown list that you can insert into a label style, just like the built in parameters.
ShawnMcCorkle1211
Message 6 of 6 (979 Views)
06-22-2013 05:27 AM in reply to: sboon
Thanks for the help.  That worked perfectly.
For some reason the Expression Option was not present. After repeated closing and restarting C3D, it finally appeared.
