Member
litstalker
Message 1 of 12 (1,281 Views)
Vertical Curve labels -- flipping problems
1281 Views, 11 Replies
04-08-2012 10:49 AM
I am having a lot of problems with my vertical curve labels. I created a style that shows the length of the vertical curve, the k-value, the end and start elevations, and the elevation and station of the PVI, as shown. My problems are the fact that when I want to flip a label, they all flip (shown in the second picture). I also have noticed that there is only one drag point. Is this a setting that I unknowingly edited, or is it possible to flip labels individually?
So you want both flipped on one curve only, right?
When you use the "flip" it is only the labels but the anchor should do what you want.
Make sure to hold "CTRL" before selecting.
http://screencast.com/t/lWetH4XNi3
klugb
Message 2 of 12 (1,257 Views)
Re: Vertical Curve labels -- flipping problems
04-09-2012 08:21 AM in reply to: litstalker
Hold down the "CTRL" key then select just the label you want to change.
Bruce
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP2)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
Member
litstalker
Message 3 of 12 (1,251 Views)
04-09-2012 11:40 AM in reply to: litstalker
That works for my grade labels, but not for the vertical curve labes, unfortunately; they still flip all together. Thanks for the help, though!
klugb
Message 4 of 12 (1,228 Views)
04-09-2012 01:55 PM in reply to: litstalker
Bruce Klug
Win 7 Pro, 64-bit
Member
litstalker
Message 5 of 12 (1,221 Views)
04-09-2012 02:56 PM in reply to: klugb
Thanks, that did help. It didn't occur to me to try moving the anchor point too.
Jay_B
Message 6 of 12 (980 Views)
01-08-2013 07:05 PM in reply to: klugb
Bruce,
We're in the process of some styles updates & one of the items I need to fix is the flip functionality in our VC Sag & Crest Pfl label styles. I came accross this video and the style used is doing exactly what we're trying to set up as far as the curve text flipping in same relationship to the dimension line along with the diamond grip flippig along with label. I can get everything except the relationship to the dim line is always above or below the original relationship to dim line. Ie: If curve text started above dim line when flipped it moves to below dim line.
Would it be possible to get a copy of the style used so i can compare & try to get our label flipping as your's does?
Assuming one or more of our anchors etc. within the stye is a little buggered up. I've looked at the "out of the box ones" and several others & none behave quite as nice as shown.....
Thanks in advance,
Jay
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
klugb
Message 7 of 12 (975 Views)
01-08-2013 07:44 PM in reply to: Jay_B
Sure, do you need 2012 or 2013?
Bruce Klug
Win 7 Pro, 64-bit
Jay_B
Message 8 of 12 (964 Views)
01-09-2013 05:15 AM in reply to: litstalker
Bruce,
We're using 2012.
if you'd like me to send you an email you can reply to I still have your email from a previous post you helped me out with.
Thanks!
Jay
Jay
C3D 2014 SP2
klugb
Message 9 of 12 (953 Views)
01-09-2013 07:16 AM in reply to: Jay_B
I don't mind posting it, I used a lot of other templates to steal ideas from when setting up ours.
Bruce Klug
Win 7 Pro, 64-bit
Jay_B
Message 10 of 12 (950 Views)
01-09-2013 07:32 AM in reply to: litstalker
Thanks Bruce.
The help is Very much appreciated!
Jay
Jay
C3D 2014 SP2
