Civil 3D Forum
Vertical Curve labels -- flipping problems
11 REPLIES 11
Message 1 of 12
4085 Views, 11 Replies
I am having a lot of problems with my vertical curve labels. I created a style that shows the length of the vertical curve, the k-value, the end and start elevations, and the elevation and station of the PVI, as shown. My problems are the fact that when I want to flip a label, they all flip (shown in the second picture). I also have noticed that there is only one drag point. Is this a setting that I unknowingly edited, or is it possible to flip labels individually?
11 REPLIES 11
Message 2 of 12
klugb
Hold down the "CTRL" key then select just the label you want to change.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 3 of 12
That works for my grade labels, but not for the vertical curve labes, unfortunately; they still flip all together. Thanks for the help, though!
Message 4 of 12
klugb
So you want both flipped on one curve only, right?
When you use the "flip" it is only the labels but the anchor should do what you want.
Make sure to hold "CTRL" before selecting.
http://screencast.com/t/lWetH4XNi3
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 5 of 12
in reply to: klugb
Thanks, that did help. It didn't occur to me to try moving the anchor point too.
Message 6 of 12
Jay_B
in reply to: klugb
Bruce,
We're in the process of some styles updates & one of the items I need to fix is the flip functionality in our VC Sag & Crest Pfl label styles. I came accross this video and the style used is doing exactly what we're trying to set up as far as the curve text flipping in same relationship to the dimension line along with the diamond grip flippig along with label. I can get everything except the relationship to the dim line is always above or below the original relationship to dim line. Ie: If curve text started above dim line when flipped it moves to below dim line.
Would it be possible to get a copy of the style used so i can compare & try to get our label flipping as your's does?
Assuming one or more of our anchors etc. within the stye is a little buggered up. I've looked at the "out of the box ones" and several others & none behave quite as nice as shown.....
Thanks in advance,
Jay
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 12
klugb
in reply to: Jay_B
Sure, do you need 2012 or 2013?
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 8 of 12
Jay_B
Bruce,
We're using 2012.
if you'd like me to send you an email you can reply to I still have your email from a previous post you helped me out with.
Thanks!
Jay
C3D 2018.1
C3D 2016 SP4
Message 9 of 12
klugb
in reply to: Jay_B
I don't mind posting it, I used a lot of other templates to steal ideas from when setting up ours.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 10 of 12
Jay_B
Thanks Bruce.
The help is Very much appreciated!
Jay
C3D 2018.1
C3D 2016 SP4
Message 11 of 12
in reply to: Jay_B
You can also <ctrl> select the label and select the "Below" option under properties... "Anchor Dimension Option".  I do this and then switch to a style I have setup for labels below.
Message 12 of 12
Jay_B
Civ_Engineer,
That's what I ended up doing, Bruce's video showing the anchor to below & many of the settings within the curve label style in his dwt & then I created a flipped or below profile crve labels & what this add's is I'm able to use Lt instead of Rt Justifed text for below option. Additionally I was able to keep the relationship of the curve text to the end points of the Begin / End lines as in caption.
C3D 2018.1
C3D 2016 SP4
Rail Community
