I am having an issue with my label displaying in my profile after I create my plan and profile sheet set. The PVC, PVI and PVT all show up, but the labels are not displaying. I looked through the layers and they are all thawed. Just wondering if anyone has any suggestions.
Solved by Jay_B. Go to Solution.
When I create the sheet set, the original dwg gets xref'ed in and a new set of profiles are created, but when the new profiles are created the labels are missing.
If you're creating new profiles are you setting the correct Profile Label Set when you do that?
I'm not sure what you mean by "a new set of profiles are created".
Are you creating a new profile view and a new profile, or are you data shortcutting the alignment and the profile, and creating a reference of that profile on a new profile view?
Mark Green
Working on Civil 3D in Canada
Sounds like perhaps an incomplete label set?
If you Right click on the profile missing the labels_Edit Labels_Import Label Set_Import your standard labels here.
These can also be preset in the Command Settings for "Profile Views" and up the tree another step be overridden t the "Feature Settings" level for Profile Views. (see attached).
