I am having an issue with my label displaying in my profile after I create my plan and profile sheet set. The PVC, PVI and PVT all show up, but the labels are not displaying. I looked through the layers and they are all thawed. Just wondering if anyone has any suggestions.
Solved by Jay_B. Go to Solution.
What is your setup?
xrefs, data shortcuts, etc...?
Mark Green
Working on Civil 3D in Canada
When I create the sheet set, the original dwg gets xref'ed in and a new set of profiles are created, but when the new profiles are created the labels are missing.
If you're creating new profiles are you setting the correct Profile Label Set when you do that?
I'm not sure what you mean by "a new set of profiles are created".
Are you creating a new profile view and a new profile, or are you data shortcutting the alignment and the profile, and creating a reference of that profile on a new profile view?
Mark Green
Sounds like perhaps an incomplete label set?
If you Right click on the profile missing the labels_Edit Labels_Import Label Set_Import your standard labels here.
These can also be preset in the Command Settings for "Profile Views" and up the tree another step be overridden t the "Feature Settings" level for Profile Views. (see attached).
Thanks Jay_B, this worked.
Can you tell me though my Civil 3d is not intuitive at all? 😀
