AutoCAD Civil 3D General Discussion
Valued Contributor
basman12
Message 1 of 10 (1,185 Views)
vertical curve for pipe network??
1185 Views, 9 Replies
09-01-2011 04:22 AM
hello everybody
i want to draw a water pipe network and i wanted to be 1.6 meter under the ground level
any suggestions how to mange this my pipe network is PE material
i try to copy the profile and offset to -1,6 but i want to use the option of creat pipe network
and produce it in the profile view
but how can i make the network follow the ground level profile ????
 i need to add vertical curve to the network or somthing similar??
 can i divide the pipes in the profile view by adding the structures direct to profile view
thanks
*Pro
dgordon
Message 2 of 10 (1,180 Views)
Re: vertical curve for pipe network??
09-01-2011 05:09 AM in reply to: basman12
how about a picture of what your seeing now.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
DSM_dude
Message 3 of 10 (1,134 Views)
09-02-2011 08:36 AM in reply to: basman12
If I'm not mistaken, you cannot add any curves to a pipe network.
Cad Blog:
http://geauxcad.wordpress.com/
*Expert Elite*
Neilw
Message 4 of 10 (1,129 Views)
09-02-2011 09:08 AM in reply to: DSM_dude
You can add curved pipes to a pipe network. When laying out a pipe notice the command prompt. You should see an option for making it a curved pipe.
There have been many posts about using pipe networks to model water pipes. While the pipe tools are very limited for this type of piping, there are several workarounds. Try a search for Water pipes and pressure pipes in the forums for solutions.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Mentor
Hidden_Brain
Message 5 of 10 (1,116 Views)
09-02-2011 11:05 AM in reply to: Neilw
just to clarify Neilw's reply, you can add horizontal curves to pipes, but not vertical curves, as far as i am aware.
Avishek Chhibber, P.E., CFM
Civil 3D 2014 SP2, Win 7-64 bit
8GB RAM
*Expert Elite*
mathewk
Message 6 of 10 (1,102 Views)
09-03-2011 06:35 AM in reply to: basman12
You can sort of emulate a vertical curve by creating several pipes in the location of the curve, this tesselating the curve. Not a good workaround but that's all there is currently.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Mentor
Hidden_Brain
Message 7 of 10 (1,099 Views)
09-03-2011 07:29 AM in reply to: basman12
Thanks for confirming Matt. Yeah, that's what I have been doing for now. Hopefully this functionality will get added very soon!
8GB RAM
*Expert Elite*
mathewk
Message 8 of 10 (1,093 Views)
09-03-2011 09:12 AM in reply to: basman12
I, You, and everyone else who uses C3D for utilities :smileyhappy:.
Matt Kolberg
New Member
SBHayes
Message 9 of 10 (664 Views)
04-01-2013 09:40 AM in reply to: basman12
"i want to draw a water pipe network and i wanted to be 1.6 meter under the ground level
and produce it in the profile view"
What I do is create a second surface from at an offset & create a surface profile from it.
-Create Tin Surface (ie. PE Min. Cover)
-Modify Surface --> Paste Surface --> Proposed Grade
-Modify Surface --> Raise/lLower Surface --> <-1.6>
Then add the surface to the profile and follow it manually.
*Expert Elite*
Jay_B
Message 10 of 10 (656 Views)
04-01-2013 10:09 AM in reply to: SBHayes
For WM using Gravity PN's this can be done by:
1. Draw a polyline representing the PN in plan view.
2. Create Feature Line from object using "Assign Elevations", choose "from surface", check "Insert intermediate grade break points".
3. Select Feature Line to view the many vertices, Weed the extra vertices by Modify Tab>Edit Elevations Panel>Delete Elevation Points. (This option will let you hover along feature line & click delete the unwanted additional vertices by clicking at green circle grips) Weed vertices will also work but may not be desirable depending on terrain.
4. Select Feature Line>Rt. click>Raise/Lower by -1.6m.
5. Create PN from object>Specify Parts List, Pipe & Null Structure>check "Use vertex Elevations", Vertex Elevation Reference>Outside top.
By applying pipe end styles at the "Null structures", Ellipse/Crossing pipe end's. Tee crossings etc. can easily be shown by also placing a null structure representing every intersecting WM branch run etc.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
