Civil 3D Forum
vertical curve for pipe network??
9 REPLIES 9
Message 1 of 10
3602 Views, 9 Replies
hello everybody
i want to draw a water pipe network and i wanted to be 1.6 meter under the ground level
any suggestions how to mange this my pipe network is PE material
i try to copy the profile and offset to -1,6 but i want to use the option of creat pipe network
and produce it in the profile view
but how can i make the network follow the ground level profile ????
 i need to add vertical curve to the network or somthing similar??
 can i divide the pipes in the profile view by adding the structures direct to profile view
thanks
9 REPLIES 9
Message 2 of 10
how about a picture of what your seeing now.
Message 3 of 10
Jonathan3891
If I'm not mistaken, you cannot add any curves to a pipe network.
Jonathan Norton
Blog | Linkedin
Message 4 of 10
Neilw_05
in reply to: Jonathan3891
You can add curved pipes to a pipe network. When laying out a pipe notice the command prompt. You should see an option for making it a curved pipe.
There have been many posts about using pipe networks to model water pipes. While the pipe tools are very limited for this type of piping, there are several workarounds. Try a search for Water pipes and pressure pipes in the forums for solutions.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 5 of 10
Hidden_Brain
in reply to: Neilw_05
just to clarify Neilw's reply, you can add horizontal curves to pipes, but not vertical curves, as far as i am aware.
Message 6 of 10
mathewkol
You can sort of emulate a vertical curve by creating several pipes in the location of the curve, this tesselating the curve. Not a good workaround but that's all there is currently.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 10
Hidden_Brain
Thanks for confirming Matt. Yeah, that's what I have been doing for now. Hopefully this functionality will get added very soon!
Message 8 of 10
mathewkol
I, You, and everyone else who uses C3D for utilities :).
Matt Kolberg
Message 9 of 10
"i want to draw a water pipe network and i wanted to be 1.6 meter under the ground level
and produce it in the profile view"
What I do is create a second surface from at an offset & create a surface profile from it.
-Create Tin Surface (ie. PE Min. Cover)
-Modify Surface --> Paste Surface --> Proposed Grade
-Modify Surface --> Raise/lLower Surface --> <-1.6>
Then add the surface to the profile and follow it manually.
Message 10 of 10
Jay_B
For WM using Gravity PN's this can be done by:
1. Draw a polyline representing the PN in plan view.
2. Create Feature Line from object using "Assign Elevations", choose "from surface", check "Insert intermediate grade break points".
3. Select Feature Line to view the many vertices, Weed the extra vertices by Modify Tab>Edit Elevations Panel>Delete Elevation Points. (This option will let you hover along feature line & click delete the unwanted additional vertices by clicking at green circle grips) Weed vertices will also work but may not be desirable depending on terrain.
4. Select Feature Line>Rt. click>Raise/Lower by -1.6m.
5. Create PN from object>Specify Parts List, Pipe & Null Structure>check "Use vertex Elevations", Vertex Elevation Reference>Outside top.
By applying pipe end styles at the "Null structures", Ellipse/Crossing pipe end's. Tee crossings etc. can easily be shown by also placing a null structure representing every intersecting WM branch run etc.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
