In the process of creating a profile I made the mistake of erasing my vertical curve data. How can I relabel my vertical curves? Know I can just use my dimensions but I really want to learn how to use labels. Fumbling in the dark. Anybody got a light?
Solved by Sinc. Go to Solution.
If you have a label set created, select the Profile, right-click ->Edit Labels and click on the "Import Label Set".
If you don't have a label set created, use this dialog box to setup all the labels the way you want, then save them as a label set so you can use the label set in the future (and make sure the label set gets into your drawing template).
Thanks so much. The label set is a great idea. I figured out that I just needed to go back and add the sag and crest labels to the Profile labeling. I think the hardest part of Civil 3D is figuring out how to create and use labeling. There are just so many options especially in profile labeling. thanks again.
Once you have your label set created you can set that as the default in the command settings and it will be applied when create a profile.
