I am hoping someone else has encountered this but I've searched and came up with nothing.
We have a road model created with a couple of side roads and junctions. The main road has a simple 6m wide assembly with verge and earthworks. The problem only occurs on my computer where the verge feature line seems to be replaced with a feature line called sod and therefore the verge line and subsequent tadpoles do not show up in the plan view. The weird thing about this is that the verge line and tadpoles show up on the side roads just not on the main road.
Can anyone shed any light on this.
C3D 2013.
Gavin
Make Sure the feature line is set in the corridor properties, Set feature lines you dont want to see to no display and make sure you see the ones you do. My code set style wont change the feature lines in the corridor properties, feature lines tab
The Code Set Style is simply a style that's stored within the drawing or dwt.
Open the drawing that's not showing your code set properly and also open a drawing that contains the "modified the basic 'plan view' code set style".
Set the incorrect drawing as the current window (switch window command) on view tab.
Got to Settings Tab of Toolspace>change the view at top to "Master View", (it's likely on Drawing settings view)>General>Multipurpose Styles>Code Set Styles>Drag and drop the basic 'plan view' code set style onto your screen.
This will overwrite the code set in the current drawing and now the drawings should both contain the updated code set.
