As a workaround, it's relatively simple to create a label style that will
accomplish what we need in Texas. Change the dragged state to not display a
leader and place the vertical label in the profile view where necessary.
I ran into another issue with this in that we can't currently snap to the PI
of a vertical curve to draw a vertical line to the bottom of the profile
band.
sm
Scott McEachron
The D.C. CADD Company - Dallas
"Daniel Philbrick" wrote in message
news:41b87882$1_2@newsprd01...
> Jeff,
> your requirement is currently not supported in the bands. However, this
> is
> a good suggestion and we will work it into future planning. (Including
> the
> missiing MO property field).
> There is a way to get it done in Civil 3D but it is not a very elegant
> work-around. You can label major stations on your profiles. This
> labeling
> will let you to set different major station labels at different station
> ranges (and increments) on the profile. However, you will have to set
> the
> beginining station and ending station for the vertical curve on the
> profile
> labels dialog. To get to this dialog, select the profile, right click,
> Edit
> Labels. On that dialog you can set the station range for the major
> station
> label - and you can add station labels for multiple ranges. You can also
> set an "absolute" elevation for the label in the Profile View. However,
> if
> you edit the Profile, the vertical curve stations (on the label dialog)
> will
> not update accordingly.
> Dan Philbrick
> Autodesk, Inc.
> "jsears" wrote in message
> news:28454488.1102454376761.JavaMail.jive@jiveforum2.autodesk.com...
>> My office just bought C3D a couple weeks ago, and the task of developing
> standard styles has fallen on me. I have been able to make considerable
> progress by using the discussion group archives. I have not yet found the
> answer to this question, however. I am using bands to label my proposed
> geometry in a profile because it is our convention to label everything
> along
> the bottom axis of the profile view. The regulating authorities require
> that the profile elevation be called out on twenty-five foot intervals in
> vertical curves. I have not found a way to label the twenty-five and
> seventy-five foot stations in my vertical curve. As far as i can tell, it
> is not possible to create a child style for a single label in a band. I
> also have not discovered a way to label the MO in a VC either. If anyone
> has any pointers or suggestions, I would appreciate it.
>> Jeff Sears, EIT
>> GEES Inc.
>> Ponder, TX
