New Member
kkaraagac
Message 1 of 4 (300 Views)
vba - Label Component - Reference Text Objects
300 Views, 3 Replies
05-17-2012 02:32 AM
How to reach Reference Text Object in Vba?
We can add Reference Text in Label Components. it can be referenced to Alignment, COGOPoint, Parcel, etc. For example, after that it is needed to select a COGO Point, and Label is changed from "???" to a property of selected Reference Object. I want to add Reference Text by VBA.
Thanks in advance,
Jeff_M
Message 2 of 4 (294 Views)
Re: vba - Label Component - Reference Text Objects
05-17-2012 06:29 AM in reply to: kkaraagac
Two things....
There is a forum specifically for customization questions: HERE
The Reference Text Component can be read, but you cannot set the object used in it programatically. At least not that I've been able to ascertain.
New Member
kkaraagac
Message 3 of 4 (279 Views)
05-17-2012 09:35 PM in reply to: Jeff_M
Thanks Jeff.
"...The Reference Text Component can be read..."
Forget about setting a reference text programatically, it is enough to reach or read reference text component. could you please write an example with 2-3 lines here?
Jeff_M
Message 4 of 4 (271 Views)
05-18-2012 06:39 AM in reply to: kkaraagac
Seems as though I mis-spoke. The COM API (ActiveX used in VBA) does not expose the Label components.
