I can always fix this in VE. I would like to find out how to avoid it. It
seems to pop up in some dwg's, not all.
Tomorrow's another day.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"Drew Burgasser" wrote in message
news:5675523@discussion.autodesk.com...
Hi John:
1. Go ahead and add to the wrong project.
2. Check out and then you should have the option to detach.
3. Save drawing back to original location.
4. Add to project and you should have the option to select a different
project.
Is this not the case?
Sincerely,
Drew Burgasser
CAD Masters, Inc.
www.cadmasters.com
"John Mayo" wrote in message
news:5675454@discussion.autodesk.com...
Hey Drew,
James picked up on that as well but if I right-click on the file I don't get
a detach project option.
I found another with the same issue. Another capture.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
news:5675372@discussion.autodesk.com...
Hi John:
It looks like 2_150102-TopoSur is p
redisposed to the 2497 project. Have you
referenced any data from the 2497 project into this drawing?
If so, and you have since deleted that data from the drawing, I think you
may have to go ahead and add it to the 2497 project. Check it out, "detach
project", save it back to its original location, and then add to project.
At this point, you should be given the option of selecting the correct
project.
Maybe someone will come up with an easier way.
Sincerely,
Drew Burgasser
CAD Masters
, Inc.
www.cadmasters.com
news:5675308@discussion.autodesk.com...
Doh!
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:5675305@discussion.autodesk.com...
You forgot the images....
