1.) None, you can backup the vault and place it on the network server when
it becomes an option. When loggin into the network vault you will change
the server name from localhost to the name of your network server.
2.)No, you will need to do a vault backup and then restore the vault on the
network server.
3.) No see above
4.)Yes, see above
5.) You could leave it and work on the vault of your chosing, no conflict
that I am currently aware. You can uninstall the vault components from your
machine.
Nick Zeeben
Engineered Efficiency
C3D 2007
XP Tablet and Pro
wrote in message news:5180908@discussion.autodesk.com...
1) if i install a "local server" on my pc now, what problems am i going to
experience later when we upgrade to a network server?
2) can i simply copy the files from the local server to the network server?
3) will i have to recreate everything in the local vault on the new network
vault?
4) will i be able to "redirect" from local to network vault on work i do now
once we upgrade?
5) once we upgrade will i have to remove the local server from my pc? are
there any issues with doing that?
TIA
