Civil 3D Forum
Variable slope to surface
5 REPLIES 5
LASSAADTH
1107 Views, 5 Replies
hello,
Can someone help me on SAC, I have a road project when a portion of the embankment must be a variable slope of 1:1 to 3: 1,as input,I have PR1 and PR2 and the ditance L between the two PR, also I have the slope (PR1) and slope (PR2).
thank you for giving me your suggested for codify a SA that solve my problem.
thank you in advance.
Lassaad THALJAOUI
Infrastructure Engineer
Autodesk Product professional User
Civil 3D 2016 x64 / Windows 7 64-bit / 16GB RAM
5 REPLIES 5
Ibarra10
in reply to: LASSAADTH
It is really hard from my understading to transition subassemly daylight slopes. I would try a different method and use grading creation tools if possible. And use the transition command between the slopes.
Ibarra10
in reply to: Ibarra10
If you are using grading creation tools, use the Transition Command between the 2:1 and 3:1 gradings. Refer to both links if needed.
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/E...
mathewkol
Peter Funk created a subassembly that transitioned a daylight slope over a station range. It may suit your needs.
http://forums.autodesk.com/t5/autocad-civil-3d-general/transition-between-daylight-regions/td-p/4421...
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
LASSAADTH
in reply to: mathewkol
I'll look in detail SAC element of PETER. I think that's what I need
Thank you for putting me on the right track.
Lassaad THALJAOUI
david.zavislan
You could use superelevation to create a variable daylight slope.   Assign any unused superelevation parameters to the slope value of your custom daylight subassembly.
This is done by using API functions to access superelevation data in the slope property of the point element.  Look in the API section of the help document  for examples of using the SE API functions in SAC expressions.
IF((Side=Left)AND(SE.HasLeftLO),SE.LeftLO,myDefaultSlope)
David Zavislan, P.E. | Wood Rodgers, Inc.
Rail Community
