Active Member
george.skinner
Message 1 of 4 (205 Views)
using ViewCube tool leads to crash
205 Views, 3 Replies
01-29-2013 08:58 AM
I often get a crash after using the ViewCube tool to pick front view while in top view (today I was in tilemode 1, in a fairly simple 3D drawing). I didn't see any past posts on this. Any suggestions? Thanks.
tcorey
Message 2 of 4 (199 Views)
Re: using ViewCube tool leads to crash
01-29-2013 10:02 AM in reply to: george.skinner
Is your video card certified by Autodesk? From the Command prompt, type 3dConfig. Press View Tune Log. The report will tell you.
After you close the tune log, press Manual Tune and turn off Hardware Acceleration. Does that reduce the crashing?
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Member
george.skinner
Message 3 of 4 (190 Views)
01-29-2013 12:50 PM in reply to: tcorey
Must be some other issue. The computer was already set up as you described. But thank you for the suggestion.
Product Support
AlmasSuljevic
Message 4 of 4 (159 Views)
02-01-2013 07:42 AM in reply to: george.skinner
This looks lot like the issue described here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15851876&linkID=9240697
Do you by any chance run Civil 3D 2011?
In any case, I would suggest to tun on/off hardware acceleration as already suggested and see if you notice any difference. The next step would be to check your graphic drivers. There should be a link on that page, as well.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
