Civil 3D Forum
Using UCS to rotate
5 REPLIES 5
1691 Views, 5 Replies
Using UCS to rotate
Hi, I haven't used UCS in awhile and I cant remember what I need to do when I want to rotate the drawing in my paper space.. I typed UCS--> 3 ---> pick my new axis and then the x,y indicator on the bottom left changes to how I want it to be presented but the drawing itself doesnt..
Pic1 is how it is normally and Pic 2 is how I want it
5 REPLIES 5
tschau3
Use the PLAN command with the "Current" option.
"Plan=>current" is exactly right. I even open up the UCS settings and name the UCS so I can pick it out in later vp's.
Anthony MacDonald, E.I.T.
WLC Engineering, Surveying and Planning
Gillette, Wyoming
[Civil 3D 2010 SP2, Windows XP SP3, Intel Core2 6600 @2.4GHz, 2.40GHz, 3.25 GB RAM]
CADvisers
An easier method that I use all the time is > Express Tools > Align Space...
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
AllenJessup
Having learned this years ago. I prefer the Dview > Twist method. After I have the MS view as I want it. I save it as a View. That way if I happen to pick a coordinate from the viewport. I don't have to worry that the UCS might have change it.
Allen Jessup
CAD Manager - Designer
doni49
I agree.  I like to know that the coordinates are right.
For that reason, I wrote the following lsp routine. It uses DView>Twist to rotate my view & sets ortho mode to match the screen.
(defun dtr (x)(* pi (/ x 180.0)))
(defun rtd (x) (* x (/ 180.0 pi)))
(defun c:dvtwist()
  (setq pt1(getpoint "Select the first point:  "))
  (setq pt2(getpoint "Select the second point:  " pt1))
  (setq ang(angle pt1 pt2))
  (command "Dview" "" "tw" (- 0 (rtd ang)) "")
  (setvar "snapang" ang)
P.S.  You pick two points that you want to represent your new horizontal (the first being your new left side).
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Rail Community
