Distinguished Contributor
dibr0804
Message 1 of 6 (756 Views)
Using UCS to rotate
756 Views, 5 Replies
07-26-2010 08:29 AM
Hi, I haven't used UCS in awhile and I cant remember what I need to do when I want to rotate the drawing in my paper space.. I typed UCS--> 3 ---> pick my new axis and then the x,y indicator on the bottom left changes to how I want it to be presented but the drawing itself doesnt..
Pic1 is how it is normally and Pic 2 is how I want it
Use the PLAN command with the "Current" option.
Distinguished Mentor
tschau3
Message 2 of 6 (754 Views)
Re: Using UCS to rotate
07-26-2010 08:32 AM in reply to: dibr0804
Active Member
tmacdonald
Message 3 of 6 (712 Views)
07-26-2010 01:38 PM in reply to: dibr0804
"Plan=>current" is exactly right. I even open up the UCS settings and name the UCS so I can pick it out in later vp's.
Anthony MacDonald, E.I.T.
WLC Engineering, Surveying and Planning
Gillette, Wyoming
[Civil 3D 2010 SP2, Windows XP SP3, Intel Core2 6600 @2.4GHz, 2.40GHz, 3.25 GB RAM]
Valued Contributor
CADvisers
Message 4 of 6 (314 Views)
12-27-2012 07:04 AM in reply to: dibr0804
An easier method that I use all the time is > Express Tools > Align Space...
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
AllenJessup
Message 5 of 6 (302 Views)
12-27-2012 08:11 AM in reply to: dibr0804
Having learned this years ago. I prefer the Dview > Twist method. After I have the MS view as I want it. I save it as a View. That way if I happen to pick a coordinate from the viewport. I don't have to worry that the UCS might have change it.
doni49
Message 6 of 6 (237 Views)
01-03-2013 01:58 PM in reply to: dibr0804
I agree.  I like to know that the coordinates are right.
For that reason, I wrote the following lsp routine. It uses DView>Twist to rotate my view & sets ortho mode to match the screen.
(defun dtr (x)(* pi (/ x 180.0)))
(defun rtd (x) (* x (/ 180.0 pi)))
(defun c:dvtwist()
  (setq pt1(getpoint "Select the first point:  "))
  (setq pt2(getpoint "Select the second point:  " pt1))
  (setq ang(angle pt1 pt2))
  (command "Dview" "" "tw" (- 0 (rtd ang)) "")
  (setvar "snapang" ang)
P.S.  You pick two points that you want to represent your new horizontal (the first being your new left side).
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
