I have a simple driveway corridor along a steep hillside. For cut, I would like to have a negative slope away from the shoulder edge. I have tried numerous approaches and all 'cut' reverts to positive. I searched and found no clear answer. It's such a short driveway, I can 'fake' it in, but I would like to calculate quantities. What is the answer? Why is this so complicated? Thanks.
Using 2012 sp1, 64bit, windows 7
Solved by apweng. Go to Solution.
In the programmers terminology "cut" is always upwards, and there is no such thing as a negative cut slope.
How are you building this slope - grading objects or corridor?
There are several subassemblies that will allow you to force a downhill slope from the road shoulder to a specified distance or elevation, then back up to the ground surface. A drawing or sketch showing what you already have and what you're trying to achieve would be helpful.
Well, I tried that. It will work if I specify only cut, but it won't display. See attached. I just need to specify a simple bench cut. Suggestions?
LinkSlopeToSurface may not be the appropriate choice for this situation. If you want to enforce a downhill slope to a surface which is a cut situation then there is a workaround using the DaylightGeneral sub to do this.
DaylightGeneral builds a series of temporary links out to a test point, which is normally at the outside corner of a ditch. If this point is in cut then it continues to build the rest of the ditch and daylight. If any part of the temporary links are in cut, but the test point is in fill then it works backward along the links until it finds an intersection with the surface and daylights there. For your scenario I would put the test point at the end of the first temporary link, and make that link at the correct slope but very long so that the test point would always end up in fill.
It may not be overly apparent - but if you use LinkSlopetoSurface and in Subassembly Properties, specify Fill Only, the Subassembly will project a "downward" slope, in a Cut condition.
I've attached an image that shows something similar. Note the Subassembly Properties (Fill Only) and how this parameter is interpreted in the Corridor Section Editor.
Hope this helps.
Andrew
The default daylight subassemblies have conditions that do not allow negative slope values. Using Subassembly Composer you can create your own daylight subassembly that does not have any restrictions on slope value.
Attached is an example subassembly that I use for these conditions.
Hi David,
This is a very useful tip.
I am fairly new to Civil 3D.
I download the NV5SimpleSlopeAlowsNegative.pkt source file.
I imported the file to my tool Palettes.
Is this file replaced LinkSlopeToSurface?
I reconstructed my assembly. I still couldn't get it to work.
This does not replace any stock subassemblies. You import it into your tool palette and add it to your assembly like any of the other subassemblies.
It only has parameters for side, cut slope, and fill slope. The slope parameters will allow negative values. This lets your model daylight up in fill situations, and down in cut. You just need to make sure that the slope values are flatter than the target grade so that they will have a chance to catch.
@Anonymous wrote:
I am curious if there are any version limitations with the "NV5SimpleSlopeAlowsNegative.pkt" that you created. This worked well for me in 2014 but will not work in 2011
Try downloading the pkt file again and then import the latest download directly into 2011. Once a pkt file has been opened in any newer version 2014, it can't be used in previous versions.
Don Ireland
Engineering Design Technician
Don Ireland
Dave, Thanks for posting. I came across your post, and tried your assembly. My condition has a need for negative cuts but with varying slope conditions. Sometimes a 2% cut clope will work, but in other cases I need a 2:1. Could you offer any help on this?
Thanks!
