Civil 3D Forum
Using Divide Command
2 REPLIES 2
jsbarnby
494 Views, 2 Replies
Hey guys. When using the divide command small points are left behind with an undefined elevation (0) and are a pain in the but to remove. Does anyone know a quick way of removing these remains or a way so that actual points are not used with the divide command?
2 REPLIES 2
MDC_quadej
in reply to: jsbarnby
What I do to be able to see the points is change the setvar for PDMODE to 3. This will show the points with an X. You could also change the size with PDSIZE. A quick way to erase all the AutoCAD points in the drawing is to use the QSELECT command. Select the Object type of "Point" and Operator of "Select All", then erase the selection set.
HTH,
Jack
When you use the divide command the acad point is the default entity to
designate the division. You could assign a block to be place at the
interval. Also, a QSELECT filtering POINT will help clean up.
Thanks, Joe
Joseph D. Bouza, P.E. (one of 'THOSE' People)
Civil 3D 2008
Win XP pro
v 2002, sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200 @2.53 GHz
3 GB RAM
NIVDIA Quadro FX 1700 (512MB)
"All Contours are Lies! "-( AJ)
The mantra of a former Flamer:
If you are forced to eat an Elephant, don't complain about it; Take one bite
at a time.
In memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
"An Equal Opportunity Annoyer" (DK)
Rail Community
