Valued Contributor
civ_engineer
Message 1 of 7 (236 Views)
Using an Expression gives "invalid input"
236 Views, 6 Replies
01-15-2013 12:42 PM
Is this a bug and is there a fix?  I'm trying to use an expression for text height and everytime I enter the name of the expression I get "Invalid Input".   Is there a trick to doing this?
I even changed a style that "HAD" allowed me to use an expression, to a number then tried to reenter the same expression name that was there and get "Invalid Input".
Civil 3D SP2.1
64 bit
windows 7
Are you trying to type the name in?
You should be able to select it like a drop-down menu.  Have you edited the expression or changed the Format?
Jeff_M
Message 2 of 7 (234 Views)
Re: Using an Expression gives "invalid input"
01-15-2013 12:50 PM in reply to: civ_engineer
What expression? What label type? What version of C3D?
AllenJessup
Message 3 of 7 (224 Views)
01-15-2013 12:59 PM in reply to: civ_engineer
You're getting Invalid Input when entering the Name of the Expression? I'd try closing and restarting Civil 3D.
Valued Contributor
civ_engineer
Message 4 of 7 (222 Views)
01-15-2013 01:12 PM in reply to: Jeff_M
Civil 3D 2012 SP2.1
It seems like I can't use expression anywhere I did before.  i.e Text height in a label style.
much less use a new one...
troma
Message 5 of 7 (215 Views)
01-15-2013 01:18 PM in reply to: civ_engineer
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
civ_engineer
Message 6 of 7 (211 Views)
01-15-2013 01:35 PM in reply to: troma
Well, I'll be... I was typing it in because there isn't a drop down arrow like in 2011.. but when I rolled my mouse wheel I saw my expression name and was able hit enter to lock it in... I wish Autodesk wouldn't "FIX" things that aren't broken... lol
Thanks troma, that's been bugging me for a while.
Jeff_M
Message 7 of 7 (203 Views)
01-15-2013 01:49 PM in reply to: civ_engineer
Have you changed the size of your Windows screen fonts? There was a bug in Windows/.NET, at one time (not sure if it's still there or not) where the ends of dialog box items, such as the one you are trying to edit, do not show up when the system font size is set to anything other than 100%.
