Civil 3D Forum
Userdefined contours from datashortcut surface not working?
11 REPLIES 11
Message 1 of 12
ralstogj
847 Views, 11 Replies
Hi
I have a existing ground surface drefed into a model and am trying to get a user defined contour at a set elevation
but nothing appears. I have userdefined layer on in the surface style and other ideas why it will not appear?
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
11 REPLIES 11
Message 2 of 12
Joe-Bouza
in reply to: ralstogj
works on my end. is the user layer off in the drawing layer dialog?
Joe Bouza
Message 3 of 12
ralstogj
in reply to: Joe-Bouza
Checked that just after posting and the layer is on. I am 2012 I see you are in 2011 I would of thought would be something easy and not a bug
Regards
Justin Ralston
Message 4 of 12
Jeff_M
Works for me in 2012 SP1, Justin. Dumb question, I know, but does the UDC elevation exist in the surface?
Jeff_M, also a frequent Swamper
Message 5 of 12
ralstogj
in reply to: Jeff_M
yep, I can make them in the source file of the dref which is what I am doing to work round the problem and cut and paste into my working drawing. Both drawing used the same base template, maybe it is some setting used in creating the dref?
Regards
Justin Ralston
Message 6 of 12
Jeff_M
Could you send me your files? There's nothing in the data shortcut that would preclude this, so it has to be something in (or not in) the drawing.
Message 7 of 12
ralstogj
in reply to: Jeff_M
Here is a link to the files
https://sites.google.com/site/c3dxtreme/home/11513-2_Lot%2032%20and%2033%20-%20Standard.zip?attredir...
Regards
Justin Ralston
Message 8 of 12
Jeff_M
Well now, isn't that just special? I'm seeing no reason why the UDC's shouldn't display, an Elevation analysis works ok. I do get a number of fatal errors, and subsequent Recover/Audits report as finding and fixing errors. I suspect these are stemming from the Grading Objects. I'll continue to look into this as time permits. It's not the surface, or the fact that it's dref'ed, as I can start a new drawing, dref the surface, and create/display UDC's at will.
Message 9 of 12
Jeff_M
in reply to: Jeff_M
I spoke too soon. The Surface Mask is preventing the UDC's from displaying. Remove the mask, the UDC's show up. This seems like a bug to me.
Message 10 of 12
ralstogj
in reply to: Jeff_M
Good spotting Jeff once the mask is removed it works for me as well. I was just using the mask to cut down the surface  to reduce regen times etc as per best practice. Definitely som thing that should be fixed. I my look into cropped surfaces as well but I do not think you can crop an dref?
Regards
Justin Ralston
Message 11 of 12
Jeff_M
@ralstogj wrote:
... but I do not think you can crop an dref?
Nope.
Message 12 of 12
jmayo-EE
in reply to: Jeff_M
It's still in 2020. Any 2021  or 22 users who can confirm it is still there.
John Mayo
Rail Community
