I’m having a user profile issue on one computer. I have a user, using windows 7 and AutoCAD Civil 3D 2014 on his work station. When using Civil 3D he has two issues: one, he cannot import Dgn’s. I’ve tried everything it just won’t work. Second, he cannot xref or insert PDF’s into a drawing. Now the reason why I say this is a profile issue is because if I log on to his computer (or anyone else log’s on his computer), I can do all those things in Civil 3D, import DGN’s & insert/xref PDF’s. If this user log’s on my computer, he can do all those things in Civil 3D. Import DGN’s & insert/xref PDF’s. Something with his profile on his computer is corrupt and I’m trying to fix it without deleting and creating another user profile. Does anyone have any idea’s?
Solved by michael.robertson. Go to Solution.
When you say you don't want to delete/create another user profile do you mean Windows user profile or C3D profile?
I mean windows profile. I'm assuming this is a windows issue. Could I be wrong?
Yes, most of the user problems we encounter are C3D profiles.
See following article: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13288548&linkID=9240697
Joe Bouza
