I am working on using User-Defined Property Classifications to be able to add measure down data to survey points. I have created fields for depth of measure down, pipe size, and direction. I have also created an equation that will give me invert elevation of the pipe. Now when I go to enter the measure down information using the edit point command, all of the columns for the pipe information seems to be in no specific order.
My question is how do I get this to show up so that all the information for pipe 1 line up next to each other making it far easier to enter. I would like to be able to have this setup in my drawing template so I don't have to remove and then add each column in the correct order for each drawing.
Thanks...
Aaron,
Try arranging the columns by dragging each heading over to where you want it.
Dave
Dave Stoll
Las Vegas, Nevada
Dave,
Yes that is a solution, but I have 32 different columns that could possibly be needed to be filled in. I don't really want to be dragging them around everytime. I am looking for a way to set it up in my project template so I can avoid that.
Aaron
Aaron,
I'm not understanding. Why would you have to arrange them more than once?
Dave
Dave Stoll
Las Vegas, Nevada
Is it not holding the column locations when you drag and drop them within the Panorama? It does for me.
If you look at my attachment I would like the columns to look like this:
Measure Down 4 Pipe Size 4 Pipe Direction 4 Invert 4
Right now they seem to be appearing in a random fashion where I have to move them to be correct. I don't want to have to move them.
Just to be clear, if you move the columns once, do they not come back up next time in the same order? That works for me.
