Civil 3D Forum
user defined coordinate system with a rotation
4 REPLIES 4
pottsk1
732 Views, 4 Replies
I know how to define a local coordinate system, but I haven't had to define one with a rotation. I can't find where to put the rotation in at. I am using the calibration sheet from our tremble office software. I have all the information to build it, but without being able to put in the rotation angle I know it won't be correct. Anyone know where or how to find this?
Thanks in advance
Kim
Kim Potts
AutoCAD/Survey Tech
Merritt LS L.L.C..
743 Horizon Ct. Suite 100B
Grand Junction, CO 81506
4 REPLIES 4
Pointdump
in reply to: pottsk1
Kim,
A little more information, please. Are you creating a custom projection using a Calibration Report*? Unless you are trying to create something like an Oblique Mercator Projection, I don't understand why you need to "rotate" anything. Better to pull the lats and longs and ellipsoid heights from your control points and use those to create a low-distortion projection.
*Calibrations warp the space/time continuum. A very bad thing indeed.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
pottsk1
in reply to: Pointdump
I think I need to rephrase. The rotation I have is in my local grid system.
Kim Potts
AutoCAD/Survey Tech
Merritt LS L.L.C..
kcobabe
I think what you are looking for is under the Transformations tab in the Drawing Settings.
Toolspace->Settings Tab->Transformations
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
pottsk1
in reply to: kcobabe
This is exactly what I was looking for Thanks!
Kim Potts
AutoCAD/Survey Tech
Merritt LS L.L.C..
Rail Community
