Experts, I am stuck in cul-de-sac design and I have just few hours to our submission.
I am modeling a cul-de-sac and I am getting a gap as attached in screen shots. This is the simplest form of CDS design I am doing. This is my first time and I did lot of reading online. However in real life site design, I am just not able to figure out what could be the problem.
For time being I am not even trying to daylight it to surface so as to avoid target surface errors.
I would sincerely appreciate if you guys can look at the attached screen shots and tell me what I may be doing obviously wrong
Regards, Mayur
Solved by mathewkol. Go to Solution.
You must have an alignment that follows the cul-de-sac. Once you have that, you must have 2 different assemblies. One of them will stop at the ER (the full road section). The assembly that goes around the cul-de-sac will have the assembly marker at the back of curb. See image below...
Todd & Matt,
sincerely appreciate your quick reply.
Matt you were spot on. There was nothing wrong with CDS. Just that there were no curves and hence graphically it looked like there is gap. After adding curves it looked exactly I was expecting.
Again thanks a lot you guys.
Regards, Mayur
