AutoCAD Civil 3D General Discussion
Active Contributor
tsachi
Message 1 of 6 (109 Views)
Updating surface after reciving new survey
109 Views, 5 Replies
08-06-2013 10:47 PM
I created a surface based on survey data, recently i recivied an updated survay (new DTM).
Is there a quick and painless way to update the surface? Obviously this surface is the basis for my entire design 8)
T. Krendel-Eltan Civil Eng. 2002
Active Contributor
dtucker
Message 2 of 6 (91 Views)
Re: Updating surface after reciving new survey
08-07-2013 04:08 AM in reply to: tsachi
Is your surface created from point groups? If so, Import your survey data, update your point groups and rebuild your surface. You may still need to update boundary definitions, breaklines, etc.
Active Contributor
tsachi
Message 3 of 6 (88 Views)
08-07-2013 04:23 AM in reply to: dtucker
Only problem is that the site is hugh, the number of points and breaklines is staggering.
My localized version has a rotine which translates the survey DTM files to a surface.
How about merging 2 surfaces? (the new surface on top of the old).
Valued Mentor
IanMcClain
Message 4 of 6 (69 Views)
08-07-2013 07:14 AM in reply to: tsachi
What does the updated DTM include? Only changes or the whole surface?
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
Active Contributor
tsachi
Message 5 of 6 (64 Views)
08-07-2013 07:21 AM in reply to: IanMcClain
The updated DTM contains the original survey data and some added areas that need to be designed.
the point file alone contains some 113,000 elevations, the breakline file is roughly the same number of points.
Valued Mentor
ericcollins6932
Message 6 of 6 (57 Views)
08-07-2013 07:53 AM in reply to: tsachi
If you have overlapping survey (enough was picked up to tie into original ground around the edges), you can paste the new surface to the old surface.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
Announcements
Need installation help?
