Civil 3D Forum
Updating surface after reciving new survey
5 REPLIES 5
tsachi
214 Views, 5 Replies
I created a surface based on survey data, recently i recivied an updated survay (new DTM).
Is there a quick and painless way to update the surface? Obviously this surface is the basis for my entire design 😎
T. Krendel-Eltan Civil Eng. 2002
5 REPLIES 5
dtucker
in reply to: tsachi
Is your surface created from point groups? If so, Import your survey data, update your point groups and rebuild your surface. You may still need to update boundary definitions, breaklines, etc.
tsachi
in reply to: dtucker
Only problem is that the site is hugh, the number of points and breaklines is staggering.
My localized version has a rotine which translates the survey DTM files to a surface.
How about merging 2 surfaces? (the new surface on top of the old).
IanMcClain
in reply to: tsachi
What does the updated DTM include? Only changes or the whole surface?
Ian McClain
tsachi
in reply to: IanMcClain
The updated DTM contains the original survey data and some added areas that need to be designed.
the point file alone contains some 113,000 elevations, the breakline file is roughly the same number of points.
ericcollins6932
in reply to: tsachi
If you have overlapping survey (enough was picked up to tie into original ground around the edges), you can paste the new surface to the old surface.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Rail Community
