I have a set of drawings with a large number of sheets. I need to do a mass edit of the properties for each sheet (for example update the revision number, date, checked/design/approved/drafting initials, description). The updated properties are largely similiar.
Is it necessary to update each sheet's custom properties individually, or is there an easier method?
No easy build in way.
Try a trail version of http://www.jtbworld.com/SSMPropEditor.htm
Cost very reasonable for the time it will save you.
Joe Bouza
